В ответ на: GENRE DE PRODUIT VEHICULE UTILITAIRE MARQUE COMMERCIALE, TYPE ORGANE PEUGEOT LIGNE DE PRODUIT PARTNER VU (M59) SILHOUETTE FOURGON COURT ’600’ FINITION NIVEAU 2 MOTEUR DIESEL TURBO DW10TD TRANSMISSION BVM5 TYPE DE PEINTURE PEINTURE METALLISEE VERNIE COULEUR DE CAISSE KMH - PEINTURE BLEU GRAND PAVOIS TYPE D’HABILLAGE INTÉRIEUR TISSU ARSINOE "PG" COULEUR DE GARNISSAGE "FZ" BOITE DE VITESSES (CARACTÉRISTIQUES) BVM BE4 L MOTEUR (TYPE) MOTEUR TYPE EW/DW MONOGRAMME COMPLÉMENTAIRE, DIVERS SANS MONOGRAMME COMPLEMENTAIRE MONOGRAMME PARTNER + HDI Caractéristiques véhicule FINITION NIVEAU 2 TYPE DE PEINTURE PEINTURE METALLISEE VERNIE COULEUR DE CAISSE KMH - PEINTURE BLEU GRAND PAVOIS TYPE D’HABILLAGE INTÉRIEUR TISSU ARSINOE "PG" COULEUR DE GARNISSAGE "FZ" BOITE DE VITESSES (CARACTÉRISTIQUES) BVM BE4 L COUPLE TACHYMÈTRE CT 19 X NO Alimentation moteur VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION SIEMENS CHAINE DE TRACTION HYBRIDE SANS CHAINE TRACTION HYBRIDE MOTEUR DIESEL TURBO DW10TD ALIMENTATION INJECTION TURBO DIRECTE DÉTECTEUR D’EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL CARBURANT GAZOLE DÉPOLLUTION (MOTEUR) DEPOL CEE 2000 (MOTEUR) PRÉFILTRE MONTAGE SANS PREFILTRE MOTEUR (TYPE) MOTEUR TYPE EW/DW MOTEUR REFROIDISSEMENT RADIATEUR EP:27 - 21,3 DM2 MBA HP RÉCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER AUTODIAGNOSTIC EOBD SANS AUTO-DIAGNOSTIC "EOBD" DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE W4 VENTILATEUR 1 VENTILATEUR 2 VITESSES 140W AERO Boîte de vitesses Transmission TRANSMISSION BVM5 BOITE DE VITESSES (CARACTÉRISTIQUES) BVM BE4 L COUPLE RAPPORT CP 19 X 70 COUPLE TACHYMÈTRE CT 19 X NO STYLE ROUE ROUE TOLE 14 POUCES DIFFÉRENTIEL (BOITE) DIFFERENTIEL 77 PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 175/65 R14 88/90T RENFORCE ROUE (TYPE) MONTAGE ROUE TOLE BOITE DE VITESSES TYPE BVM BE4R Suspension Direction Freinage VARIANTE ASSOCIÉE FREIN ABS BOSCH 8 0 ANTIBLOCAGE ANTI-BLOCAGE ROUE BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 21 ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 21 FREIN TYPE DISQUES AV VENTILES/TAMBOURS AR SUSPENSION SUSPENSION NORMALE CONTRÔLE DYNAMIQUE DE STABILITÉ SANS SYSTEME ESP Carrosserie Equipements ANTENNE ANTENNE PAVILLON COURTE ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX TEINTE MASSE ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX LARG = 95 ENJOLIVEUR ROUE (STYLE) CABOCHON CACHE MOYEU COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR ESSUIE-VITRE AVANT ESSUIE-VITRE AV SANS CAPTEUR DE PLUIE ESSUIE-VITRE ARRIÈRE ESSUIE-VITRE AR ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR GIRAFON SANS GIRAFON SONDE TEMPÉRATURE EXTÉRIEURE SANS SONDE TEMPERATURE EXT PORTE LATÉRALE DE CHARGEMENT SANS PORTE LATERALE COULISSANTE PARE-CHOCS P/C AV/AR TEINTE MASSE PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CDE MANUELLE RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CDE ELECTRIQUE ROUE DE SECOURS ROUE TOLE + PNEU STANDARD ACCESSOIRES EXTÉRIEURS POIGN EXT+ENJ VOLET+RETRO EXT NEUTRES SUPPORT ROUE DE SECOURS SUPPORT ROUE SECOURS STANDARD TOIT OUVRANT TOIT FIXE VITRE ARRIÈRE (GENRE) VITRE AR CHAUFFANTE VITRE (ASPECT) TEINTEE VITRE (TYPE) PARE-BRISE ATHERMIQUE VITRE LATÉRALE (POUR UTILITAIRE SEULEMENT) SANS VITRE LATERALE Equipement intérieur TYPE D’HABILLAGE INTÉRIEUR TISSU ARSINOE "PG" ALARME ANTIVOL SANS ALARME ANTIVOL CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE AVEC ALARME CLIMAT (TEMPERATURE AMBIANTE) PAYS TEMPERES CLIMATISEUR AVEC RECYCLAGE AIR GRADUATION VITESSES GRADUATION EN KM/H COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE COMMANDE À DISTANCE MONTAGE CDE A DISTANCE CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL FEUX INT. DIVERS LECTEUR DE CARTE TABLETTE DE TRAVAIL SANS TABLETTE TRAVAIL GARNISSAGE VOLUME CHARGEMENT TAPIS COFFRE PVC+COTES MOQUETTE COMBINÉ (CARACTÉRISTIQUES) GRADUATION 210 KM/H 135 M/H FOND NOIR HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE COMMANDE ASSISE AVANT CONDUCTEUR COMMANDE ASSISE CONDUCTEUR MANUELLE COMMANDE ASSISE AVANT PASSAGER COMMANDE ASSISE PASSAGER AVANT MANUELLE RABATTEMENT ASSISE AVANT CONDUCTEUR SANS RABATTEMENT ASSISE AV CONDUCTEUR RABATTEMENT ASSISE AVANT PASSAGER SANS RABATTEMENT ASSISE AV PASSAGER ACCOUDOIR ASSISE AVANT SANS ACCOUDOIR AVANT SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE SEQUENTIELLE LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE ELECTRIQUE AFFICHEUR AFFICHEUR (MONTRE ET OU T°) MIROIR DE COURTOISIE MIROIR COTE PASSAGER SANS ECLAIRAGE INDICATEUR D’HUILE RECEPTEUR NIVEAU HUILE NAPPE CHAUFFANTE SIEGE NON CHAUFFANT SAC GONFLABLE LATÉRAL AVANT SANS SAC GONFLABLE LATERAL AV PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR SAC GONFLABLE PASSAGER SANS SAC GONFLABLE PASSAGER ORDINATEUR DE BORD SANS ORDINATEUR DE BORD RÉTROVISEUR EXTÉRIEUR RETRO EXT CHAUFFANT NEUTRALISATION COUSSIN GONFLABLE SANS NEUTRALISATION COUSSIN GONFLABLE PANNEAU MOBILE ARRIÈRE VOLET PORTE LATÉRALE DE CHARGEMENT SANS PORTE LATERALE COULISSANTE PROJECTEUR CORRECTEUR ASSIETTE REGLAGE MANUEL A DISTANCE PROJECTEURS PROTECTION POSTE AVANT TOLE ETANCHE FIXE RÉCEPTEUR RADIO SYSTEME AUDIO "RD3" RÉFRIGÉRATION REFRIGERATION RÉGULATEUR DE VITESSES SANS REGULATION VITESSE SAC GONFLABLE CONDUCTEUR SAC GONFLABLE COTE CONDUCTEUR RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE TAPIS MOQUETTE DILOURS F330 DÉTECTION D’OBSTACLE SANS DETECTEUR OBSTACLE ADAPTATION GARNITURE POMMEAU LEVIER VITESSE INSERT NON PEINT SURTAPIS SANS SURTAPIS COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION VITRE ARRIÈRE (GENRE) VITRE AR CHAUFFANTE VITRE (TYPE) PARE-BRISE ATHERMIQUE VITRE LATÉRALE (POUR UTILITAIRE SEULEMENT) SANS VITRE LATERALE VOLANT VOLANT STANDARD VENTILATEUR 1 VENTILATEUR 2 VITESSES 140W AERO Electricité ALTERNATEUR ALTERNATEUR CLASSE 15 BATTERIE BATTERIE L2 400 COMMANDE À DISTANCE MONTAGE CDE A DISTANCE DÉMARREUR DEMARREUR CLASSE 4 ECLAIREMENT PARTICULIER SANS ECLAIRAGE PARTICULIER FEUX INT. DIVERS LECTEUR DE CARTE FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA 433,92 MHZ HETERODYNE MISE EN CHARGE VÉHICULE ÉLECTRIQUE SANS PRISE MISE EN CHARGE VEHICULE PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD PROJECTEUR CORRECTEUR ASSIETTE REGLAGE MANUEL A DISTANCE PROJECTEURS Marques d'équipements VARIANTE ASSOCIÉE FREIN ABS BOSCH 8 0 VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION SIEMENS Divers CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE PRISE D’ÉCOUTE RADIO PRISE ACCESSOIRES EQUIPEMENT DE SECOURS SANS EQUIPEMENT SECOURS MISE EN CHARGE VÉHICULE ÉLECTRIQUE SANS PRISE MISE EN CHARGE VEHICULE ACCESSOIRES EXTÉRIEURS POIGN EXT+ENJ VOLET+RETRO EXT NEUTRES
VF3GBRHYB96119695 НадіслатиPARTNER VU (M59) КОРОТКИЙ ФУРГОН '600' 2.0 HDi 90 КПП 5
Характеристики автомобиля
Модель PARTNER VU (M59) N° APV/PR 10228 FV 1 0270 Дата начала гарантии 29.11.2004 Общая информация ТИП ПРОДУКТА ФУРГОН НА ЛЕГКОВОМ ШАССИ ТОРГОВЫЙ ЗНАК/ТИП КОМПОНЕНТА ПЕЖО МОДЕЛЬНЫЙ РЯД PARTNER VU (M59) КУЗОВ КОРОТКИЙ ФУРГОН ’600’ УРОВЕНЬ ОТДЕЛКИ УРОВЕНЬ 2 ДВИГАТЕЛЬ ТУРБО ДИЗЕЛЬ DW10TD КОРОБКА ПЕРЕДАЧ BVM5 ТИП КРАСКИ ОКРАСКА МЕТАЛЛИК ЦВЕТ КУЗОВА KMH - КРАСКА - ПОСЕЙДОН БЛЮ (СИНЯЯ) ТИП ВНУТРЕННЕЙ ОТДЕЛКИ ТКАНЬ ARSINOE "PG" ЦВЕТ ОБИВКИ "FZ" КОРОБКА ПЕРЕДАЧ (ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ) BE4-5L РУЧНАЯ КОРОБКА ПЕРЕДАЧ ДВИГАТЕЛЬ (ТИП) EW/DW ДРУГИЕ НАКЛЕЙКИ, РАЗНОЕ " БЕЗ ДОПОЛН. ЭМБЛЕМЫ ЭМБЛЕМЫ PARTNER + ДВИГАТЕЛЬ HDI Характеристики автомобиля УРОВЕНЬ ОТДЕЛКИ УРОВЕНЬ 2 ТИП КРАСКИ ОКРАСКА МЕТАЛЛИК ЦВЕТ КУЗОВА KMH - КРАСКА - ПОСЕЙДОН БЛЮ (СИНЯЯ) ТИП ВНУТРЕННЕЙ ОТДЕЛКИ ТКАНЬ ARSINOE "PG" ЦВЕТ ОБИВКИ "FZ" КОРОБКА ПЕРЕДАЧ (ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ) BE4-5L РУЧНАЯ КОРОБКА ПЕРЕДАЧ ПРИВОД СПИДОМЕТРА CT 19 X NO Система питания топливом ВАРИАНТЫ КОНФИГУРАЦИИ СИСТЕМЫ ВПРЫСКА СИСТЕМА ВПРЫСКА SIEMENS ГИБРИДНЫЙ ПРИВОД БЕЗ ЦЕПИ ГИБРИДНОЙ ТЯГИ ДВИГАТЕЛЬ ТУРБО ДИЗЕЛЬ DW10TD СИСТЕМА ПОДАЧИ ТОПЛИВА СИСТЕМА ВПРЫСКА ТУРБОДИЗЕЛЯ С НЕПОСРЕДСТВЕННЫМ ВПР ДАТЧИК ВОДЫ В ФИЛЬТРЕ ОЧИСТКИ ДИЗЕЛЬНОГО ТОПЛИВА БЕЗ ДАТЧИКА ВОДЫ ФИЛЬТРА ДИЗ.ТОПЛИВА ТОПЛИВО ДИЗЕЛЬНОЕ ТОПЛИВА СТАНДАРТ ПО ВЫБРОСАМ ОТРАБОТАВШИХ ГАЗОВ В АТМОСФЕРУ (ДВИГАТЕЛЬ) EEC 2000 ОЧИСТКА (ДВИГАТЕЛЬ) ФИЛЬТР ПРЕДВАРИТЕЛЬНОЙ ОЧИСТКИ СБОРКА БЕЗ ПРЕДВАРИТ. ФИЛЬТРА ДВИГАТЕЛЬ (ТИП) EW/DW ЭЛЕКТРОДВИГАТЕЛЬ СИСТЕМЫ ОХЛАЖДЕНИЯ РАДИАТОР ТОЛЩ.:27 - 21,3 ДМ2 MBA HP ПОДОГРЕВ ГАЗОВОГО ТРАКТА КАРТЕРА БЕЗ ГАЗОВОГО КОНТУРА КОРП.ОТОПИТ. БОРТОВАЯ СИСТЕМА САМОДИАГНОСТИКИ EOBD БЕЗ САМОДИАГНОСТИКИ "EOBD" ТЕХНИЧЕСКИЕ СРЕДСТВА ДЛЯ ЗАЩИТЫ ОКРУЖАЮЩЕЙ СРЕДЫ АВТОМОБИЛЬ С ТЕХН. ОЧИСТКОЙ W4 ВЕНТИЛЯТОР 1 ВЕНТИЛЯТОР 2-СКОРОСТНОЙ, 140 ВТ "AERO" Коробка передач - Трансмиссия КОРОБКА ПЕРЕДАЧ BVM5 КОРОБКА ПЕРЕДАЧ (ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ) BE4-5L РУЧНАЯ КОРОБКА ПЕРЕДАЧ ПЕРЕДАТОЧНОЕ ОТНОШЕНИЕ ГЛАВНОЙ ПЕРЕДАЧИ КОМПЛ.ГИП.ШЕСТ.ЗАДНЕЙ ОСИ 19 X 70 ПРИВОД СПИДОМЕТРА CT 19 X NO СТИЛЬ КОЛЕС КОЛЕСО СТАЛЬНОЕ ШТАМПОВАННОЕ 14-ДЮЙМОВОЕ ДИФФЕРЕНЦИАЛ (КОРОБКА ПЕРЕДАЧ) ДИФФЕРЕНЦИАЛ 77 ШИНЫ (ТИП, РАЗМЕР) ШИНА 175/65 R14 88/90T УСИЛЕННАЯ КОЛЕСО (ТИП) СТАЛЬНЫЕ ДИСКИ ТИП КОРОБКИ ПЕРЕДАЧ КОРОБКА ПЕРЕДАЧ BE4R Подвеска Рулевое управление Тормозная система ВАРИАНТЫ КОНФИГУРАЦИИ ТОРМОЗНОЙ СИСТЕМЫ ABS BOSCH 8 0 ABS С ТОРМОЗАМИ С СИСТЕМОЙ АБС ЗАДНИЙ СТАБИЛИЗАТОР ПОПЕРЕЧНОЙ УСТОЙЧИВОСТИ ЗАДН.СТАБ.ПОПЕР.УСТОЙЧИВ. ДИАМ. 21 ПЕРЕДНИЙ СТАБИЛИЗАТОР ПОПЕРЕЧНОЙ УСТОЙЧИВОСТИ ПЕР.СТАБИЛ.ПОПЕР.УСТОЙЧ.ДИАМ. 21 ТИП ТОРМОЗА ВЕНТИЛИР. ПЕРЕДНИЕ ДИСКИ/ЗАДН.БАРАБАНЫ ПОДВЕСКА ОБЫЧНАЯ ПОДВЕСКА ДИНАМИЧЕСКАЯ СИСТЕМА ПОДДЕРЖАНИЯ УСТОЙЧИВОСТИ БЕЗ ПРОГРАММЫ ЭЛЕКТРОННОЙ СТАБИЛИЗАЦИИ Кузов Оборудование АНТЕННА КОРОТКАЯ АНТЕННА НА КРЫШЕ БОКОВОЙ МОЛДИНГ (ТИП) БОК.ЗАЩ.НАКЛАДКИ ОБЪЕМ. ОКРАШ. БОКОВОЙ МОЛДИНГ (РАЗМЕРЫ) БОКОВЫЕ ЗАЩИТНЫЕ ЭЛЕМЕНТЫ, ШИРИНА =95 ДЕКОРАТИВНЫЕ ЭЛЕМЕНТЫ КОЛЕС (СТИЛЬ) ДЕКОРАТИВНЫЙ БОЛТ КРЫШКИ СТУПИЦЫ ДОПОЛНИТЕЛЬНЫЙ ЭКРАН (ПОД ДВИГАТЕЛЕМ) БЕЗ ЗАЩИТЫ КАРТЕРА ДВИГАТЕЛЯ СТЕКЛООЧИСТИТЕЛЬ ВЕТРОВОГО СТЕКЛА ЩЕТ.СТЕКЛООЧ.ЛОБ.СТ. БЕЗ ДАТЧИКА ДОЖДЯ ЗАДНИЙ СТЕКЛООЧИСТИТЕЛЬ СТЕКЛООЧИСТИТЕЛЬ ЗАДНЕГО СТЕКЛА ОЧИСТИТЕЛЬ ФАР БЕЗ СТЕКЛООЧИСТИТЕЛЯ ФАР ЗАДНИЙ ДЕРЖАТЕЛЬ НА КРЫШЕ БЕЗ ЛЮКА В КРЫШЕ ДАТЧИК ТЕМПЕРАТУРЫ ОКРУЖАЮЩЕГО ВОЗДУХА БЕЗ ДАТЧИКА ТЕМПЕРАТУРЫ НАРУЖНОГО ВОЗДУХА ЗАДНЯЯ ДВЕРЬ БАГАЖНИКА БЕЗ СДВИЖНОЙ БОКОВОЙ ДВЕРИ БАМПЕР БАМПЕР ПЕР./ЗАД. С ОБЪЕМНОЙ ОКРАСКОЙ РЕШЕТКА БАГАЖНИКА БЕЗ БАГАЖ.РЕЛЬСОВ НА КРЫШЕ ПЕРЕДНЯЯ ПРОТИВОТУМАННАЯ ФАРА ПЕРЕДНИЕ ПРОТИВОТУМАННЫЕ ФАРЫ НАРУЖНОЕ ЗЕРКАЛО ЗАДНЕГО ВИДА (СО СТОРОНЫ ВОДИТЕЛЯ) НАР.ВОДИТ.ЗЕР. С РУЧ.УПР. БЕЗ ОБОГР. НАРУЖНОЕ ЗЕРКАЛО ЗАДНЕГО ВИДА (СО СТОРОНЫ ПАССАЖИРА) НАРУЖН. ЗЕРКАЛО ПАССАЖИРА С ЭЛЕКТР. РЕГУЛИРОВКОЙ ЗАПАСНОЕ КОЛЕСО СТАЛЬНОЙ ДИСК + СТАНДАРТНАЯ ШИНА ДОПОЛНИТЕЛЬНОЕ НАРУЖНОЕ ОБОРУДОВАНИЕ НЕЙТР.НАР.РУЧ.+ОБЛ.СТВ.+НАР.ЗЕР.ЗАД.ВИД. КРЕПЛЕНИЕ ЗАПАСНОГО КОЛЕСА СТАНД.ДЕРЖАТЕЛЬ ЗАПАСНОГО КОЛЕСА ЛЮК ФИКСИРОВАННАЯ КРЫША СТЕКЛО ЗАДНЕЙ ДВЕРИ (ТИП) ЗАДНЕЕ СТЕКЛО С ОБОГРЕВОМ СТЕКЛО (ВНЕШНИЙ ВИД) ТОПИРОВАННЫЙ ОКНО (ТИП) АТЕРМАЛЬНОЕ ВЕТРОВОЕ СТЕКЛО БОКОВОЕ ОКНО (ТОЛЬКО ДЛЯ КОММЕРЧЕСКИХ АВТОМОБИЛЕЙ) БЕЗ БОКОВОГО ОКНА Внутреннее оборудование ТИП ВНУТРЕННЕЙ ОТДЕЛКИ ТКАНЬ ARSINOE "PG" ПРОТИВОУГОННАЯ СИГНАЛИЗАЦИЯ БЕЗ ПРОТИВОУГОННОЙ СИГНАЛИЗАЦИИ ПЕРЕДНИЙ РЕМЕНЬ БЕЗОПАСНОСТИ РЕМ.БЕЗОП. С ПИРОТ.ПРЕДНАТ. И СИГНАЛ. КЛИМАТ (ТЕМПЕРАТУРА ОКРУЖАЮЩЕГО ВОЗДУХА) СТРАНЫ С УМЕРЕННЫМ КЛИМАТОМ КЛИМАТИЧЕСКАЯ УСТАНОВКА С РЕЦИРКУЛЯЦИЕЙ ВОЗДУХА ГРАДАЦИЯ НА СПИДОМЕТРЕ ГРАДУИРОВКА В КМ/Ч ПОЛОЖЕНИЕ ВО ВРЕМЯ ДВИЖЕНИЯ ЛЕВОСТОРОННЕЕ РУЛЕВОЕ УПРАВЛЕНИЕ СИСТЕМА ДИСТАНЦИОННОГО УПРАВЛЕНИЯ УЗЕЛ ДИСТАНЦИОННОГО УПРАВЛЕНИЯ ДОПОЛНИТЕЛЬНЫЙ ОТОПИТЕЛЬ БЕЗ ДОПОЛНИТЕЛЬНОГО ОТОПИТЕЛЯ РАЗНООБРАЗНЫЕ ЛАМПЫ ОСВЕЩЕНИЯ САЛОНА ЛАМПЫ ДЛЯ ПОДСВЕТКИ КАРТ СТОЛИК ДЛЯ РАБОТЫ БЕЗ РАБОЧЕГО СТОЛА ОТДЕЛКА ГРУЗОВОЙ ПЛАТФОРМЫ КОВРИК БАГАЖН. ОТДЕЛ. ПВХ + БОКОВЫЕ СТЕНКИ МОКЕТ ПАНЕЛЬ ИНСТРУМЕНТОВ (ХАРАКТЕРИСТИКИ) ГРАДУИР. 210 КМ/Ч, 135 МИЛЬ/Ч, ЦВЕТ ЧЕРНЫЙ ДИНАМИК 4 ПЕР. ГРОМКОГОВОРИТЕЛЯ (2 ВЧ + 2 ПЕР.) ОРГАНЫ УПРАВЛЕНИЯ РАДИОСИСТЕМОЙ ДИСТ.УПРАВЛ. РАДИОПРИЕМНИКОМ ВЫКЛЮЧАТЕЛЬ РЕГУЛИРОВКИ СИДЕНЬЯ ВОДИТЕЛЯ РУЧНАЯ РЕГУЛИРОВКА ПОДУШКИ СИДЕНЬЯ ВОДИТЕЛЯ ВЫКЛЮЧАТЕЛЬ РЕГУЛИРОВКИ СИДЕНЬЯ ПАССАЖИРА РУЧНАЯ РЕГУЛИРОВКА ПОДУШКИ СИДЕНЬЯ ПЕРЕДНЕГО ПАССАЖИРА СКЛАДЫВАЮЩЕЕСЯ СИДЕНЬЕ ВОДИТЕЛЯ БЕЗ СКЛАД. ПЕРЕДН. СИДЕНЬЯ ВОДИТ. СКЛАДЫВАЮЩЕЕСЯ СИДЕНЬЕ ПЕРЕДНЕГО ПАССАЖИРА БЕЗ СКЛАД. СИДЕНЬЯ ПЕРЕДН. ПАСС. ПОДЛОКОТНИК ПЕРЕДНЕГО СИДЕНЬЯ БЕЗ ПЕРЕДНЕГО ПОДЛОКОТНИКА СПУТНИКОВАЯ НАВИГАЦИОННАЯ СИСТЕМА БЕЗ НАВИГАЦИОННОЙ СИСТЕМЫ СТЕКЛОПОДЪЕМНИК ДВЕРИ СО СТОРОНЫ ВОДИТЕЛЯ ПОСЛЕД.ЭЛ.СТЕКЛОПОД.ОКНА ВОДИТ. СТЕКЛОПОДЪЕМНИК ДВЕРИ СО СТОРОНЫ ПАССАЖИРА ЭЛЕКТР.СТЕКЛОПОД.ПЕРЕД.ПАССАЖ.ОКНА ДИСПЛЕЙ ДИСПЛЕЙ (ЧАСЫ И/ИЛИ T°) ЗЕРКАЛО НА ПРОТИВОСОЛНЕЧНОМ КОЗЫРЬКЕ ЗЕРКАЛО НА СТОРОНЕ ПАССАЖИРА БЕЗ ПОДСВЕТКИ УКАЗАТЕЛЬ УРОВНЯ МАСЛА СТАНД. УКАЗАТЕЛЬ УРОВНЯ МАСЛА НАГРЕВАТЕЛЬНЫЙ ЭЛЕМЕНТ СИДЕНЬЕ БЕЗ ПОДОГРЕВА ПЕРЕДНЯЯ БОКОВАЯ ПОДУШКА БЕЗОПАСНОСТИ БЕЗ ПЕРЕДНЕЙ БОКОВОЙ ПОДУШКИ БЕЗОПАСН. ЗАЩИТА ПАССАЖИРОВ НА ЗАДНИХ СИДЕНЬЯХ БЕЗ ЗАЩИТЫ ЗАДНЕГО ПАССАЖИРА ПОДУШКА БЕЗОПАСНОСТИ СО СТОРОНЫ ПАССАЖИРА БЕЗ ПОДУШКИ БЕЗОПАСНОСТИ ДЛЯ ПАССАЖИРА БОРТОВОЙ КОМПЬЮТЕР БЕЗ КОМПЬЮТЕР НАРУЖНОЕ ЗЕРКАЛО ЗАДНЕГО ВИДА (С ПОДОГРЕВОМ) НАРУЖ.ЗЕРКАЛО ЗАДН.ВИДА С ПОДОГРЕВОМ СИСТЕМА ДЕАКТИВАЦИИ ПОДУШЕК БЕЗОПАСНОСТИ БЕЗ ОТКЛЮЧЕНИЯ ПОДУШКИ БЕЗОПАСНОСТИ ЗАДНЯЯ РАЗДВИЖНАЯ ПАНЕЛЬ ЗАДНЕЕ СТЕКЛО ЗАДНЯЯ ДВЕРЬ БАГАЖНИКА БЕЗ СДВИЖНОЙ БОКОВОЙ ДВЕРИ СИСТЕМА РЕГУЛИРОВКИ НАПРАВЛЕНИЯ СВЕТА ФАР ДИСТАНЦИОННАЯ РУЧНАЯ РЕГУЛИРОВКА ФАР ЗАЩИТА ПЕРЕДНЕГО СИДЕНЬЯ ФИКСИРОВАННАЯ НЕПРОНИЦ.ПЕРЕБОРКА РАДИОПРИЕМНИК АВТОМАГНИТОЛА "RD3" СИСТЕМА КОНДИЦИОНИРОВАНИЯ ВОЗДУХА КОНДИЦИОНЕР КРУИЗ-КОНТРОЛЬ БЕЗ УПРАВЛЕНИЯ СКОРОСТЬЮ ПОДУШКА БЕЗОПАСНОСТИ СО СТОРОНЫ ВОДИТЕЛЯ ПОДУШКА БЕЗОПАСНОСТИ ВОДИТЕЛЯ ГРУЗОВАЯ ПЛАТФОРМА БЕЗ СЕТКИ БАГАЖНИКА КОВРИК ПОКРЫТИЕ НАПОЛЬНОЕ ’ДИЛОУРС’ F330 СИСТЕМА ОБНАРУЖЕНИЯ ПРЕПЯТСТВИЙ БЕЗ ДЕТЕКТОРА ПРЕПЯТСТВИЙ АДАПТАЦИЯ ОТДЕЛКИ РУКОЯТКА РЫЧАГА КП СО ВСТАВКОЙ, НЕ ОКРАШЕННАЯ НАПОЛЬНЫЙ КОВРИК БЕЗ МАТА УПРАВЛЕНИЕ СИСТЕМОЙ БЛОКИРОВКИ ПРОСТОЙ ЦЕНТРАЛЬНЫЙ ЗАМОК СТЕКЛО ЗАДНЕЙ ДВЕРИ (ТИП) ЗАДНЕЕ СТЕКЛО С ОБОГРЕВОМ ОКНО (ТИП) АТЕРМАЛЬНОЕ ВЕТРОВОЕ СТЕКЛО БОКОВОЕ ОКНО (ТОЛЬКО ДЛЯ КОММЕРЧЕСКИХ АВТОМОБИЛЕЙ) БЕЗ БОКОВОГО ОКНА РУЛЕВОЕ КОЛЕСО СТАНДАРТНОЕ РУЛЕВОЕ КОЛЕСО ВЕНТИЛЯТОР 1 ВЕНТИЛЯТОР 2-СКОРОСТНОЙ, 140 ВТ "AERO" Электрооборудование ГЕНЕРАТОР ПЕРЕМЕННОГО ТОКА ГЕНЕРАТОР 150 А БАТАРЕЯ АККУМУЛЯТОР L2 400 СИСТЕМА ДИСТАНЦИОННОГО УПРАВЛЕНИЯ УЗЕЛ ДИСТАНЦИОННОГО УПРАВЛЕНИЯ СТАРТЕР СТАРТЕР CL 4 СПЕЦИАЛЬНОЕ ОСВЕЩЕНИЕ БЕЗ ИНДИВИДУАЛЬНОГО ОСВЕЩЕНИЯ РАЗНООБРАЗНЫЕ ЛАМПЫ ОСВЕЩЕНИЯ САЛОНА ЛАМПЫ ДЛЯ ПОДСВЕТКИ КАРТ РАБОЧАЯ ЧАСТОТА ПУЛЬТА ДИСТАНЦИОННОГО УПРАВЛЕНИЯ ЦЕНТРАЛЬНЫМ ЗАМКОМ ЧАСТОТА ДИСТАНЦИОННОО ПУЛЬТА 433,92 МГЦ, ГЕТЕРОДИН ШТЕПСЕЛЬНЫЙ РАЗЪЕМ ДЛЯ ЗАРЯДКИ ЭЛЕКТРОМОБИЛЯ БЕЗ ДАТЧИКА ЗАГРУЗКИ АВТОМОБИЛЯ ПЕРЕДНЯЯ ПРОТИВОТУМАННАЯ ФАРА ПЕРЕДНИЕ ПРОТИВОТУМАННЫЕ ФАРЫ СИСТЕМА РЕГУЛИРОВКИ НАПРАВЛЕНИЯ СВЕТА ФАР ДИСТАНЦИОННАЯ РУЧНАЯ РЕГУЛИРОВКА ФАР Марки оборудования ВАРИАНТЫ КОНФИГУРАЦИИ ТОРМОЗНОЙ СИСТЕМЫ ABS BOSCH 8 0 ВАРИАНТЫ КОНФИГУРАЦИИ СИСТЕМЫ ВПРЫСКА СИСТЕМА ВПРЫСКА SIEMENS Разное СПЕЦИАЛЬНЫЕ ХАРАКТЕРИСТИКИ СТАНДАРТ ПОЛОЖЕНИЕ ВО ВРЕМЯ ДВИЖЕНИЯ ЛЕВОСТОРОННЕЕ РУЛЕВОЕ УПРАВЛЕНИЕ РАЗЪЕМ ДЛЯ ПОДКЛЮЧЕНИЯ НАУШНИКОВ РАДИОТЕЛЕФОНА С РОЗЕТКОЙ ДЛЯ ДОПОЛН.ОБОРУДОВ. ОБОРУДОВАНИЕ ДЛЯ ЧРЕЗВЫЧАЙНЫХ СИТУАЦИЙ БЕЗ РЕЗЕРВНОГО ОБОРУДОВАНИЯ ШТЕПСЕЛЬНЫЙ РАЗЪЕМ ДЛЯ ЗАРЯДКИ ЭЛЕКТРОМОБИЛЯ БЕЗ ДАТЧИКА ЗАГРУЗКИ АВТОМОБИЛЯ ДОПОЛНИТЕЛЬНОЕ НАРУЖНОЕ ОБОРУДОВАНИЕ НЕЙТР.НАР.РУЧ.+ОБЛ.СТВ.+НАР.ЗЕР.ЗАД.ВИД.
