Autoua.netФорумToyota, Lexus, Daihatsu форум
TOYOTA -как настроить дист. открытие ворот из машины?
43 года, Киев
С нами с 24.02.2009
      16 декабря 2010 в 20:01 Гілками
Возле кнопки открытия люка амер.версии Камри есть 3 маленькие кнопки. Так вот они могут быть настроены для дистанционного открытия ворот и др. Кто-то уже настраивал?
The land of fruits and nuts.
С нами с 24.07.2001
Re: TOYOTA -как настроить дист. открытие ворот из машины? [Re: Аленчик]
      16 декабря 2010 в 21:13 Гілками
Я налаштовував. Ось копіпаста з мануалу на американську Ялинку (англійською читаєте?):
The garage door opener (
Universal Transceiver) is manufactured
under license from HomeLink and can
be programmed to operate garage
doors, gates, entry doors, door locks,
home lighting systems, and security
systems, etc.
(a) Programming the HomeLink
The HomeLink in your vehicle has 3
buttons and you can store one program
for each button.
To ensure correct programming into the
HomeLink, install a new battery in the
hand–held transmitter prior to programming.
The battery side of the hand–held transmitter
must be pointed away from the
HomeLink during the programming process.
For Canadian users, follow the procedure
in “Programming an entrance gate/programming
all devices in the Canadian
market”.
1. Decide which of 3 HomeLink buttons
you want to program. Push and hold
down one of the buttons until the indicator
corresponding to the selected
channel begins to flash.
2. Place your hand–held garage transmitter
25 to 75 mm (1 to 3 in.) away from
the surface of the HomeLink.
Keep the indicator light on the HomeLink
in view while programming.
3. Simultaneously press and hold the
hand–held garage transmitter button
along with the selected HomeLink button.
4. When the indicator light on the
HomeLink changes from a slow to a
rapid flash after 20 seconds, you can
release both buttons.
5. Test the operation of the HomeLink by
pressing the newly programmed button.
If programming a garage door opener,
check to see if the garage door opens
and closes.
If the garage door does not operate, identify
if your garage transmitter is of the
“Rolling Code” type. Press and hold the
programmed HomeLink button. The garage
door has the rolling code feature if
the indicator light (on the HomeLink)
flashes rapidly and then remains lit after
2 seconds. If your garage transmitter is
the “Rolling Code” type, proceed to the
heading “Programming a rolling code system”.
6. Repeat steps 2 through 5 for each remaining
HomeLink button to program
another device.
If your device is “Rolling Code”
equipped, it is necessary to follow
steps 1 through 4 under the heading
“Programming the HomeLink” before
proceeding with the steps listed below.
1. Locate the “training” button on the ceiling
mounted garage door opener motor.
The exact location and color of the
button may vary by brand of garage
door opener. Refer to the owner’s
guide supplied by the garage door
opener manufacturer for the location of
this “training” button.
2. Press the “training” button on the ceiling
Following this step, you have 30 seconds
in which to initiate step 3 below.
3. Press and release the vehicle’s programmed
HomeLink button twice. The
garage door may open. If the door
does open, the programming process is
complete. If the door does not open,
press and release the button a third
time. This third press and release will
complete the programming process by
opening the garage door.
The ceiling mounted garage door opener
motor should now recognize the
HomeLink unit and be able activate the
garage door up/down.
4. Repeat steps 1 through 3 for each remaining
another rolling code system.
all devices in the Canadian market
1. Decide which of the 3 HomeLink buttons
2. Place your hand–held gate/device
transmitter 25 to 75 mm (1 to 3 in.)
away from the surface of the
HomeLink.
3. Press and hold the selected
HomeLink button.
4. Continuously press and release (cycle)
the hand–held gate/device transmitter
button every two seconds until step 5
is complete.
5. When the indicator light on the
6. Test the operation of the HomeLink by
Check to see if the gate/device operates
correctly.
7. Repeat steps 1 through 6 for each remaining
another device.
Никольская Слободка
С нами с 20.04.2005
      20 декабря 2010 в 13:33 Гілками
Не знаю как на американские, а на европейские версии Тойоты система HomeLink устанавливается дополнительно. При этом, фирма - производитель и модель гаражных ворот должна находится в списке совместимых с этой системой.
С нами с 24.07.2001
Re: TOYOTA -как настроить дист. открытие ворот из машины? [Re: Алес Цурюк]
      21 декабря 2010 в 00:31 Гілками
Не знаю как на американские, а на европейские Тойоты система HomeLink устанавливается дополнительно. При этом, фирма - производитель и модель гаражных ворот должна находится в списке совместимых с этой системой.
На американських саме HomeLink стоїть з заводу.
43 года, Киев
С нами с 24.02.2009
Re: TOYOTA -как настроить дист. открытие ворот из машины? [Re: _KD_]
      21 декабря 2010 в 09:48 Гілками
Дякую, але усі наведені операції були зроблені та перероблені. Схиляюсь до думки що не співпадають частоти...
member ***
С нами с 20.01.2010
      4 января 2011 в 17:24 Гілками
Как вариант запрятать(приклеить) ваш штатный брелок за обшивкой потолка(например за фонарем осещения салона)а кнопку от брелка вывести на одну из штатных кнопок возле люка.ТОлько проверить работает он из машины или нет. Хотя дальность у него приличная должен работать.
ПАПАрация ***
С нами с 09.02.2004
      5 января 2011 в 08:07 Гілками
Там дело не только в частоте.
У первого ХоумЛинка диапазон частот 288 - 399 МГц.
Чаще всего работа с гаражными контроллерами на в Америке идёт 315 МГц и ключ Static или Roling.
А продаваемое и устанавливаемое у нас оборудование на 95% работает на 433,92 (европейский стандарт) и использует банальный Килок.
Есть еще пока редко встречающиеся системы УмногоДома на 868 МГц, но и там свои протоколы.
Хотя с 2007-го ХоумЛинк уже и европейские 433,92 поддерживает.
Скорее всего проблема в том, что ХоумЛинк "дублирует" статические и циклические ключи, а у вас на воротах Килок
Если интересно - для общего развития
Если так ничего и не выйдет, то вариант, предложенный Автоэлектриком, вполне имеет право на жизнь.
Змінено B.O.S. (08:34 05/01/2011)
43 года, Киев
С нами с 24.02.2009
Re: TOYOTA -как настроить дист. открытие ворот из машины? [Re: B.O.S.]
      22 января 2011 в 18:47 Гілками
Господа, всем спасибо! но придется носить в кармане... или когда-нибудь себя раскуркулю на перепрограммирование автомобильного Хоум линка под Nice. Вот мое раздорожье.
Модератор:  Sergu44o, moderator
Переглядів теми: 15121
