Возле кнопки открытия люка амер.версии Камри есть 3 маленькие кнопки. Так вот они могут быть настроены для дистанционного открытия ворот и др. Кто-то уже настраивал?
В ответ на: Возле кнопки открытия люка амер.версии Камри есть 3 маленькие кнопки. Так вот они могут быть настроены для дистанционного открытия ворот и др. Кто-то уже настраивал?
Я налаштовував. Ось копіпаста з мануалу на американську Ялинку (англійською читаєте?):
The garage door opener ( Universal Transceiver) is manufactured under license from HomeLink and can be programmed to operate garage doors, gates, entry doors, door locks, home lighting systems, and security systems, etc. (a) Programming the HomeLink The HomeLink in your vehicle has 3 buttons and you can store one program for each button. To ensure correct programming into the HomeLink, install a new battery in the hand–held transmitter prior to programming. The battery side of the hand–held transmitter must be pointed away from the HomeLink during the programming process. For Canadian users, follow the procedure in “Programming an entrance gate/programming all devices in the Canadian market”. 1. Decide which of 3 HomeLink buttons you want to program. Push and hold down one of the buttons until the indicator corresponding to the selected channel begins to flash. 2. Place your hand–held garage transmitter 25 to 75 mm (1 to 3 in.) away from the surface of the HomeLink. Keep the indicator light on the HomeLink in view while programming. 3. Simultaneously press and hold the hand–held garage transmitter button along with the selected HomeLink button. 4. When the indicator light on the HomeLink changes from a slow to a rapid flash after 20 seconds, you can release both buttons. 5. Test the operation of the HomeLink by pressing the newly programmed button. If programming a garage door opener, check to see if the garage door opens and closes. If the garage door does not operate, identify if your garage transmitter is of the “Rolling Code” type. Press and hold the programmed HomeLink button. The garage door has the rolling code feature if the indicator light (on the HomeLink) flashes rapidly and then remains lit after 2 seconds. If your garage transmitter is the “Rolling Code” type, proceed to the heading “Programming a rolling code system”. 6. Repeat steps 2 through 5 for each remaining HomeLink button to program another device. Programming a rolling code system If your device is “Rolling Code” equipped, it is necessary to follow steps 1 through 4 under the heading “Programming the HomeLink” before proceeding with the steps listed below. 1. Locate the “training” button on the ceiling mounted garage door opener motor. The exact location and color of the button may vary by brand of garage door opener. Refer to the owner’s guide supplied by the garage door opener manufacturer for the location of this “training” button. 2. Press the “training” button on the ceiling mounted garage door opener motor. Following this step, you have 30 seconds in which to initiate step 3 below. 3. Press and release the vehicle’s programmed HomeLink button twice. The garage door may open. If the door does open, the programming process is complete. If the door does not open, press and release the button a third time. This third press and release will complete the programming process by opening the garage door. The ceiling mounted garage door opener motor should now recognize the HomeLink unit and be able activate the garage door up/down. 4. Repeat steps 1 through 3 for each remaining HomeLink button to program another rolling code system. Programming an entrance gate/programming all devices in the Canadian market 1. Decide which of the 3 HomeLink buttons you want to program. 2. Place your hand–held gate/device transmitter 25 to 75 mm (1 to 3 in.) away from the surface of the HomeLink. Keep the indicator light on the HomeLink in view while programming. 3. Press and hold the selected HomeLink button. 4. Continuously press and release (cycle) the hand–held gate/device transmitter button every two seconds until step 5 is complete. 5. When the indicator light on the HomeLink changes from a slow to a rapid flash after 20 seconds, you can release both buttons. 6. Test the operation of the HomeLink by pressing the newly programmed button. Check to see if the gate/device operates correctly. 7. Repeat steps 1 through 6 for each remaining HomeLink button to program another device.
Не знаю как на американские, а на европейские версии Тойоты система HomeLink устанавливается дополнительно. При этом, фирма - производитель и модель гаражных ворот должна находится в списке совместимых с этой системой.
Не знаю как на американские, а на европейские Тойоты система HomeLink устанавливается дополнительно. При этом, фирма - производитель и модель гаражных ворот должна находится в списке совместимых с этой системой.
Как вариант запрятать(приклеить) ваш штатный брелок за обшивкой потолка(например за фонарем осещения салона)а кнопку от брелка вывести на одну из штатных кнопок возле люка.ТОлько проверить работает он из машины или нет. Хотя дальность у него приличная должен работать.
У первого ХоумЛинка диапазон частот 288 - 399 МГц. Чаще всего работа с гаражными контроллерами на в Америке идёт 315 МГц и ключ Static или Roling. А продаваемое и устанавливаемое у нас оборудование на 95% работает на 433,92 (европейский стандарт) и использует банальный Килок. Есть еще пока редко встречающиеся системы УмногоДома на 868 МГц, но и там свои протоколы. Хотя с 2007-го ХоумЛинк уже и европейские 433,92 поддерживает.
Скорее всего проблема в том, что ХоумЛинк "дублирует" статические и циклические ключи, а у вас на воротах Килок
Господа, всем спасибо! но придется носить в кармане... или когда-нибудь себя раскуркулю на перепрограммирование автомобильного Хоум линка под Nice. Вот мое раздорожье.
