Тоёта камри 1999 г.в., у соседа по моему дома, возникла проблема с брелком какой нужно сделать "танец с бубном" что бы войти в режим программирования брелка камасутра не помогла, может просто не смогли, может не правильный алгоритм
sit in car all doors closed put key in ignition and turn from OFF to ACC 3 times as fast as you can leaving it in ACC on the last cycle then press your remote button. your blinkers should flash to tell you this has worked....
И такое, о мастер брелке: To program the remote for a MCV20 / SXV20 camry you need the master programmed key (it's the black one you would have gotten originally with the car. you place the key in the ignition with the headlights off and the interior light off turn the car from "off" to "on" 3 or 5 times rapidly (but do not start the car). the dash security light will come on and stay on. this means the car is in program mode. you then simply press the remote button and your new remote is now programmed. additional: your old remote will not work unless you programme it at the same time as the new one.
I know there are 2 types of security system built into these cars.GQ43VT7T is for the factory remote system and uses the jumping 2 pins on mirror adjusment switch. The other is the RS3000/VIP system, which uses a different programming, closing opening doors etc.
