Замена масла в DSG-7 (DQ200)
member ***
С нами с 10.11.2008
      24 января 2014 в 15:04 Гілками
Прочитал на сайте фолькса новость от 14 Ноября 2013 о старте глобальной кампании по замене синтетического масла на минеральное в сухих коробках DQ200.
Дилер (Атлант-М) об акции ни слухом ни духом. Может кто-то уже сталкивался с этой заменой на наших просторах или есть какая информация как определить какое масло сейчас в коробке?
Volkswagen recalls Tiguan for fuse exchange
Some of the vehicle lights could fail on the Tiguan
Gearbox oil change with vehicles with DQ200 gearboxes
Within the framework of the continuous monitoring of vehicles in the field, Quality Assurance at Volkswagen AG has found that, in isolated cases, a fuse may trip in the Tiguan, thus resulting in failure of one of the two vehicle light circuits. This in turn causes individual light functions to fail. However, the vehicle's electric circuitry ensures that some lights remain on all around the vehicle. The driver is immediately informed of this on the instrument cluster.
Replacing the fuse with one with a tougher surface coating only takes a few minutes. Approximately 800,000 vehicles, which includes 147.000 vehicles in the German market, built between the beginning of 2008 and the middle of 2011, are affected by this global campaign. The relevant vehicle owners will be informed by Volkswagen accordingly.
Within the framework of further quality monitoring in China and Southeast Asia, it has been discovered that, with vehicles with a 7-speed dual-clutch gearbox (DQ200), electric malfunctions could occur in the gearbox power supply if synthetic gearbox oil is used. This applies in particular if the vehicle is subject to a hot and humid climate, coupled with a high proportion of stop & go driving.
Studies have established that using of mineral oil will rectify this problem. To continue to ensure customer satisfaction amongst DSG, Volkswagen has decided to launch global voluntary campaign and to request all customers with a 7-speed dual-clutch gearbox (DQ200) filled with synthetic oil to visit a workshop for an oil exchange. The vehicle owners will be informed by Volkswagen accordingly.
подмастерье
35 лет, Черновцы
С нами с 17.11.2012
Re: Замена масла в DSG-7 (DQ200) [Re: funarg]
      3 апреля 2014 в 20:07 Гілками
так она вроде необслуживаемая? И масло тоже не меняетсся в ней, до конца жизни? По крайней мере наши официалы такое сказали, и если чего сломалось меняют полностью коробку, отдельно узлы не меняют...
приверженец ***
Киев/Нюрнберг
С нами с 17.11.2008
      4 апреля 2014 в 11:51 Гілками
funarg 24.01.2014 15:04 пишет:
Они проводят акцию в разных странах в разное время. Сказали что до Украины волна ещё не дошла. В Израиле уже меняют...
приверженец ***
Киев/Нюрнберг
С нами с 17.11.2008
Re: Замена масла в DSG-7 (DQ200) [Re: Golden1981]
      8 апреля 2014 в 16:09 Гілками
Golden1981 04.04.2014 11:51 пишет:
Акция в Украине стартовала, проверяйте свой VIN тут: http://atlant-m.kiev.ua/ru/action-vin/
Код акции 34F6
Змінено Golden1981 (16:09 08/04/2014)
33 года за рулем, Киев
С нами с 26.05.2008
      10 апреля 2014 в 21:34 Гілками
Кто знает насчет аналогичной процедуры на Шкодах?
С нами с 18.11.2009
Re: Замена масла в DSG-7 (DQ200) [Re: Andrey007]
      18 апреля 2014 в 12:25 Гілками
знакомый на ети в раше менял
Re: Замена масла в DSG-7 (DQ200) [Re: Gheka]
      21 апреля 2014 в 08:30 Гілками
в любой коробке масло меняется не позже 120ткм или 3 года
44 года (24 года за рулем), Винница
С нами с 01.11.2011
Re: Замена масла в DSG-7 (DQ200) [Re: MadMax]
      16 июля 2014 в 12:31 Гілками
FORDMAX 21.04.2014 08:30 пишет:
Странно, сервисная книжка о этом факте ничего не знает.
подмастерье
35 лет, Черновцы
С нами с 17.11.2012
Re: Замена масла в DSG-7 (DQ200) [Re: PositiveOne]
      19 сентября 2014 в 23:19 Гілками
PositiveOne 16.07.2014 12:31 пишет:
Сервисная книжка еще не знает, пробегает ли эта коробка столько)
энтузиаст *****
Одесса
С нами с 24.02.2006
      17 октября 2014 в 18:43 Гілками
Почему в Volkswagen было принято решение о замене масла КП?
В рамках дальнейшего контроля качества в ходе эксплуатации автомобилей с 7-ступенчатой КП DSG (DQ200), особенно при воздействии высокой температуры и влажности при одновременной эксплуатации в жёстком режиме с частыми остановками и троганиями в мегаполисах, со временем удалось подтвердить влияние используемого масла КП на возникновение неисправности. Долгосрочные исследования показали, что из-за процессов электролиза в сочетании с синтетическим маслом между токопроводящими дорожками осаждаются токопроводящие частицы, которые становятся причиной неисправности. В случае применения минерального масла эта проблема устраняется.
Поэтому, чтобы по-прежнему обеспечивать удовлетворённость клиентов, эксплуатирующих автомобили с КП DSG, в Volkswagen было принято решение добровольно провести отзывные или сервисные акции и пригласить клиентов для замены масла КП на сервисные станции.
Минеральное масло необходимо заменять после определённого периода эксплуатации?
Нет, регулярно заменять масло, по-прежнему, не требуется.
Модератор:  moderator
Переглядів теми: 9450
